FANUC DCS Configuration – Setting up a DCS
This video tutorial shows how to set up a DCS – Cartesian position check using a Teach Pendant from a FANUC robot.
You have to determine the “The zone” for which you want to set a cartesian position check. Let’s say, for example, you want to set up a cartesian position check for the electrical panel of the cell. The purpose of the cartesian position check is to protect the electrical panel from the robot.
+/- 60 minutes
You can use the 4D graphic or the Roboguide to see the DCS in real-time.
A reboot of the robot controller is necessary.
Changing the DCS configuration could affect the security borders and lead to collisions with things that were previously secure by the DCS.
- SELECT –> [ 6 ] 6 SYSTEM
- SELECT –> [ 7 ] 7 DCS (see screenshot)
- Using arrow –> Scroll down to line 3 : Cart. Position check
- PRESS –> [ NEXT ] Press [NEXT] until you see F3 key as DETAIL
- PRESS –> [ F3 ] DETAIL
- Using Arrow –> Scroll down to an empty Cartesian position check that is not defined Let’s say line 4. (see screenshot)
- At line 2, PRESS –> [ ENTER ]
- ENTER –> A comment like : Panel (see screenshot)
- At line 3, PRESS –> [ F4 ] [ CHOICE ]
- SELECT –> [ 2 ] 2 Restricted zone (Diagonal). (this will set a rectangular prism where the robot will not have access.)
- At line 8, ENTER –> 0 (to set the rectangular zone reference to the World frame.)
- At line 9, 10 and 11, ENTER –> The coordinates of the two points of the diagonal, which reference is the world frame according to which the rectangular prism et located in space. (Enter these numbers -> See screenshot)
- At line 12, PRESS –> [ F4 ] [ CHOICE ]
- SELECT –> [ 1 ] 1 Stop Category 0 (This will set the robot to stop its motors immediately.)
- If the question “Do you want to change the settings?” is asked, PRESS –> [ F4 ] YES
- PRESS –> [ 2 ] 2 ENABLE
- PRESS –> [ PREV ]
- PRESS –> [ PREV ]
- PRESS –> [ F2 ] APPLY
- ENTER –> Code number (master): xxxx (Refer to Robot cell integrator for code.)
- PRESS –> [ F4 ] OK (see screenshot)
- PRESS –> [ FCTN ]
- SELECT –> [ 8 ] 8 CYCLE POWER (see screenshot)
- PRESS –> [ YES ]
- The DCS set up will be added to the one already in function. (see screenshot)
