FANUC File Management – Backing up files in text format
This is a tutorial to teach how to back up files in text format (ASCII) on a USB KEY using a Teach Pendant from a FANUC robot.
+/- 5 minutes
Use a representative backup name for your folder to keep track of your modifications more easily.
- INSERT –> USB KEY on Teach Pendant.
- PRESS –> [ 7 ] 7 FILE
- PRESS –> [ 1 ] 1 FILE (see screenshot)
- PRESS –> [ F5 ] [ UTIL ]
- SELECT –> [ 1 ] 1 Set Device (see screenshot)
- SELECT –> [ 7 ] 7 USB Disk (UD1:) (see screenshot)
- SELECT –> [ 4 ] 4 Make Dir (see screenshot)
- Using ARROW, SELECT –> Type of character you want and type desired DIR name. (BCK_ASCII, for example) (see screenshot)
- PRESS –> [ F4 ] [ BACKUP ] (see screenshot)
- SELECT –> [ 1 ] 1 ASCII
- PRESS –> [ F3 ] [ ALL ]
