FANUC File Management – Backup on USB key
One way to solve the problem of lost mastering values is to make sure you always have an updated backup available to load to your robot. The video below explains exactly how to perform a robot backup.
+/- 5 minutes
Use a representative backup name for your folder to keep track of your modifications more easily.
- INSERT –> USB KEY into the Teach Pendant.
- SELECT –> [ 7 ] 7 FILE
- SELECT –> [ 1 ] 1 FILE
- PRESS –> [ UTIL ]
- SELECT –> [ 1 ] SET DEVICE
- SELECT –> [ 7 ] 7 USB ON TP
- PRESS –> [ UTIL ]
- SELECT –> [ 4 ] 4 MAKE DIR
- WRITE DIRECTORY NAME
- PRESS –> [ BACK UP ]
- SELECT –> [ 8 ] 8 ALL OF ABOVE
- PRESS –> [ YES ]
