Setting up and calling At Perch Position
The Home position of DIY Robotics standard programming is set a Ref Position 1. It is called “At Perch”.
Robot will move directly at home so make sure that there is no collision while the task is performed.
- In T1 mode, move the robot to the desired “Home Position”.
- SELECT –> [ 6 ] 6 SETUP
- SELECT –> [ 7 ] 7 Ref_Position (see screenshot)
- Bring the cursor to “Enb/Dsbl” of # 1
- PRESS –> [ F3 ] [DETAIL]
- ENTER –> At Perch (see screenshot)
- PRESS –> [ SHIFT + F5 ] SHIFT and RECORD
- Using ARROW –> Scroll down to the third line.
- PRESS –> [ F4 ] TRUE (see screenshot)
- Using ARROW –> Scroll down to the fifth line.
- On the right column, ENTER –> 5
- Using ARROW –> Scroll down to the sixth line.
- Using ARROW –> Scroll down to the seventh line.
- Using ARROW –> Scroll down to the eight line.
- Using ARROW –> Scroll down to the ninth line.
- Using ARROW –> Scroll down to the tenth line.
- On the right column, ENTER –> 5 (see screenshot)
- PRESS –> [ PREV ]
- PRESS –> [ F4 ] ENABLE (see screenshot)
CALLING AT HOME POSITION
In a program, you have to add this program part in order to copy Ref_Pos1 in PR[1]
- Choose the program you want to add the homing command
- Using ARROW –> Choose the program.
- Using Arrow, SELECT –> Where you want to add the command. (Must be before the point line telling the robot to go to PR[1:AtPerch])
- PRESS –> [ F1 ] [INST] (if not available, PRESS –> [ NEXT ] )
- SELECT –> [ 6 ] 6 CALL
- SELECT –> [ 1 ] 1 CALL PROGRAM
- PRESS –> [ F3 ] COLLECT
- SELECT –> Karel Logs
- Using Arrow, SELECT –> GET_HOME Program
- Set the point in JOINT Motion if not already programmed
