Setting up user key macro command assignment on teach pendant
This procedure will help you create a one key press action. For example, let’s say you want to open or close a gripper by pressing a key on the teach pendant. Here’s how to do it.
+/- 10 minutes
It’s possible that some robot action happens even if you don’t see them directly on the Teach Pendant.
SETTING THE MACRO COMMAND
- PRESS –> [ F2 ] CREATE
- Using arrows, SCROLL DOWN to –> Upper case
- Using F1 to F5 keys, Enter program name « Gripper » (see screenshot)
- PRESS –> [ F2 ] DETAIL
- Using Arrow –> Scroll down to “Sub type:”
- PRESS –> [ F4 ] CHOICE
- SELECT –> [ 3 ] 3 Macro (see screenshot)
- Using Arrow –> Scroll down to “Group Mask:” (see screenshot)
- PRESS –> [ F5 ] *
- PRESS –> [ F1 ] END
- PRESS –> [ F1 ] [ INST ] (if you don’t have [INST], PRESS –> [NEXT])
- SELECT –> [ 3 ] 3 IF/SELECT
- SELECT –> [ 8 ] 8 –next page–
- SELECT –> [ 1 ] 1 IF (…) THEN (see screenshot)
- SELECT –> [ 3 ] 3 DO[ ] (see screenshot)
- ENTER –> 10
- PRESS –> [ F1 ]
- SELECT –> [ 2 ] 2 AND (see screenshot)
- ENTER –> 11 (see screenshot)
- Using Arrow –> Move cursor to left to highlight DO [11]
- PRESS –> [ F5 ] !
- Using Arrow –> Scroll down one line.
- PRESS –> [ F1 ] [INST]
- SELECT –> [ 2 ] [ I/O ] (see screenshot)
- SELECT –> [ 1 ] DO[ ]=… (see screenshot)
- ENTER –> 10
- SELECT –> [ 2 ] 2 OFF (see screenshot)
- SELECT –> [ 2 ] [I/O]
- ENTER –> 11
- SELECT –> [ 1 ] ON (see screenshot)
- SELECT –> [ 2 ] 2 ELSE (see screenshot)
- ENTER –> 11
- ENTER –> 10
- SELECT –> [ 1 ] 1 ON (see screenshot)
- SELECT –> [ 3 ] 3 ENDIF (see screenshot)
SETTING THE USER KEY
- SELECT –> [ 6 ] 6 SETUP
- SELECT –> [ 6 ] 6 MACRO (see screenshot)
- Using Arrow –> Scroll down to an empty line.
- PRESS –> [ ENTER ] (see screenshot)
- Using Arrows, SCROLL DOWN to –> Upper case
- With F1 to F5 keys, enter the name –> « Gripper » (see screenshot)
- Using Arrow –> Move cursor right to “Program” column.
- PRESS –> [ F4] [CHOICE]
- PRESS –> [ F2] MACRO
- Using Arrow –> Scroll down to “GRIPPER”.
- Using Arrow –> Move cursor right.
- PRESS –> [ 2 ] 2 UK (For User Key) (see screenshot)
- Using Arrow –> Move cursor right to “Assign” column.
- ENTER –> [1] (number 1 is selecting TOOL 1 key of the teach pendant.) (see screenshot)
CHECKING USER KEY SET UP
- PRESS –> [ I / O ]
- PRESS –> [ TOOL 1 ] (Each pressing of TOOL 1 key will alternate the state ON or OFF of DO[10: Gripper open] and DO[11:Gripper Close])
- Usable Macro Keys :
