Making point adjustments with utility function “Prog Adjust”
This procedure is used to change a series of point positions in a program.
Create a new program version to make sure you don’t lose your original points.
Make sure to respect the right referential(?) for the “Prog Adjust”.
A bad adjustment could lead to robots or tooling collisions.
- Choose the program you want to make user frame reference changes. (see screenshot)
- SELECT –> [ 1 ] 1 UTILITIES
- SELECT –> [ 5 ] 5 Prog Adjust
- PRESS –> [ F2 ] DETAIL
- Select the program in which the changes have to be made
- Using arrow –> Scroll down to the 2nd line.
- ENTER –> The number where the changes should start.
- Using arrow –> Scroll down to the 3rd line.
- ENTER –> The number where the changes should end.
- Using arrow –> Scroll down to the 4th line.
- SELECT –>[ 1 ] 1 USER (Or 2 TOOL, depending according to what the adjustment is made).
- Using arrow –> Scroll down to the 5th line.
- Enter an amount of millimeters for which the selected points will be move according to the USER frame X axis, on which they are referenced on.
- PRESS –> [ ENTER ] (if you have entered something)
- Using arrow –> Scroll down to the 6th line.
- Enter an amount of millimeters for which the selected points will be move according to the USER frame Y axis, on which they are referenced on.
- Using arrow –> Scroll down to the 7th line.
- Enter an amount of millimeters for which the selected points will be move according to the USER frame Z axis, on which they are referenced on.
- Using arrow –> Scroll down to the 8th line.
- Enter an amount of degrees for which the selected points will be move according to the USER frame W, on which they are referenced on.
- Using arrow –> Scroll down to the 9th line.
- Enter an amount of degrees for which the selected points will be move according to the USER frame P, on which they are referenced on.
- Using arrow –> Scroll down to the 10th line.
- Enter an amount of degrees for which the selected points will be move according to the USER frame R, on which they are referenced on.
- Using arrow –> Scroll down to the 11th line.
- Enter an amount of mm/s for which the speed of the selected linear or circular points will be changed.
- Using arrow –> Scroll down to the 12th line.
- Enter an amount of % for which the speed of the selected joint points will be changed. (see screenshot)
- PRESS –> [ F4 ] ENABLE (see screenshot)
- PRESS –> [ NEXT ]
- PRESS –> [ F2 ] CLR_ADJ
- PRESS –> [ F4 ] YES (This will make the adjustment permanent) (see screenshot)
- PRESS –> [ F3 ] CLR_ALL (see screenshot)
- PRESS –> [ F4 ] YES (This will clear the adjustment schedule listed on the previous page) (see screenshot)
