Accessing comment tool on WEB page
This tutorial shows how to access the comment tool on web page using a Teach Pendant from a FANUC robot.
+/- 5 minutes
- PLUG –> Your Ethernet cable to port 2 of the Omron NX-EIP coupler in the 24VDC control panel of the cell and the other end of the cable to your computer’s ethernet port.
- SELECT –> [ 6 ] 6 SETUP
- SELECT –> [ 0 ] 0 NEXT (depending on options installed)
- PRESS –> [ x ] [ HOST COMM ] (see screenshot)
- USING ARROW –> Scroll down to [ 7 Http Authentification ]
- SET ALL RESOURCES TO –> U (UNLOCK) (see screenshot)
- PRESS –> [ PREV ]
- USING ARROW –> Scroll up to [1 TCP/IP DETAILED SET UP]
- PRESS –> [ F3 ] [PORT] , until Port#1 is dispayed.
- TAKE NOTE OF –> ROBOT IP ADDRESS: 192.168.250.10
- TAKE NOTE OF –> ROBOT SUBNET MASK: 255.255.255.0
- SET YOUR –> COMPUTER LOCAL ETHERNET ADRESS: 192.168.250.1 (see screenshot)
- SET YOUR –> COMPUTER LOCAL SUBNET MASK: 255.255.255.0
- USING ARROW –> Scroll down to an empty spot on the local ethernet address list.
- ENTER –> Your computer’s local address you have previously set.
- PRESS –> [ F4 ] [PING]
- If the mention “Ping (ethernet address) succeeded” appears, then continue this procedure. Else, your network setup is not correct.
- OPEN –> Your internet browser (Chrome, Edge, etc.) and set the address to the robot’s ethernet address. (see screenshot)
- In the web page, PRESS –> [ ROBOT TOOLS ]
- In the web page, PRESS –> [ COMMENT TOOLS ]
- In the web page, PRESS –> Select the desired type of I/O and /or Registers you want to type comments. (see screenshot)
