Switching Tool Frames maintaining the same TCP position
This procedure is use to change tool frame number to a section or all of a program points without affecting TCP positions along the taught robot path.
Create a backup before making any modifications.
Make sure to have correctly teach the new tool proceeding to the tool offset.
- Choose the program you want to make tool frame reference changes.
- SELECT –> [ 1 ] 1 UTILITIES
- SELECT –> [ 8 ] 8 Tool Offset (see screenshot)
- Select the program in which the changes have to be made.
- Using Arrow –> Scroll down on the 2nd line.
- PRESS –> [ F4 ] [PART]
- Using Arrow –> Scroll down on the 3rd line.
- ENTER –> The number where the changes should start
- Using Arrows, SCROLL DOWN to the –> The 4th line
- ENTER –> The line number where the changes should end.
- Using Arrow –> Scroll down on the 5th line.
- ENTER –> A new program name (or keep the same one.)
- Using Arrow –> Scroll down on the 6th line.
- If you kept the same program name, enter a program line number where the lines with the switched tool frames will be copied. If you have changed the program name the step before, no “insert line” will be asked.
- PRESS –> [ ENTER ] (if you have entered an “insert line” number) (see screenshot)
- Using Arrow –> Scroll down until the next page appear.
- ENTER — > Old tool frame number (the frame number on which the points where reference to)
- ENTER –> New tool frame number (the tool frame number on which the points on which you want to reference them to).
- Using Arrow –> Scroll down on the 3rd line. (see screenshot)
- SELECT –> [ 1 ] 1 TCP Fixed (This convert type will keep the position of the TCP (Tool center point) where it is for each of the targeted points, but will change the face plate position of joint 6 according to the new tool to maintain TCP position along the path)
- PRESS –> [ F2 ] EXECUTE
- PRESS –> [ F4 ] YES
- You can also delete P[1] to P[5] and changed UTOOL_NUM from 1 to 3.
- DELETE –> line 4 to 9.
