Prog z_main
Prog z_main LANGUAGE: Karel CREATED: 2016-02-08 MODIFIED: 2019-11-21 CODE /PROG Z_MAIN /ATTR OWNER = MNEDITOR; COMMENT = ""; PROG_SIZE = 1932; CREATE = DATE 16-02-08 TIME 12:48:42; MODIFIED = DATE 19-11-21 TIME 11:36:30; FILE_NAME = ; VERSION = 0; LINE_COUNT = 71; MEMORY_SIZE = 2424; PROTECT = READ_WRITE; TCD: STACK_SIZE = 0, TASK_PRIORITY = 50, TIME_SLICE = 0, BUSY_LAMP_OFF = 0, ABORT_REQUEST = 0, PAUSE_REQUEST = 0; DEFAULT_GROUP = 1,*,*,*,*; CONTROL_CODE = 00000000 00000000; /MN 1: --eg:Copyright (c) 2019 DIY-Robotics.com All rights reserved. ; 2: --eg: ; 3: --eg:Redistribution and use in source and binary forms, with or without ; 4: --eg:modification, are permitted provided that the following conditions : are ; 5: --eg:met: ; 6: --eg: ; 7: --eg:Redistributions of source code must retain the above copyright ; 8: --eg:notice, this list of conditions and the following disclaimer. ; 9: --eg:Redistributions in binary form must reproduce the above ; 10: --eg:copyright notice, this list of conditions and the following : disclaimer ; 11: --eg:in the documentation and/or other materials provided with the ; 12: --eg:distribution. ; 13: --eg:Neither the name of DIY-Robotics.com nor the names of its ; 14: [...]
Standard Logic
Standard Logic LANGUAGE: Karel CREATED: 2019-10-15 MODIFIED: 2019-11-21 CODE /PROG BGLOGIC1 /ATTR OWNER = MNEDITOR; COMMENT = "StandardLogic"; PROG_SIZE = 2679; CREATE = DATE 19-10-15 TIME 12:57:46; MODIFIED = DATE 19-11-21 TIME 11:34:16; FILE_NAME = BGLOGIC1; VERSION = 0; LINE_COUNT = 73; MEMORY_SIZE = 3079; PROTECT = READ_WRITE; TCD: STACK_SIZE = 0, TASK_PRIORITY = 50, TIME_SLICE = 0, BUSY_LAMP_OFF = 0, ABORT_REQUEST = 0, PAUSE_REQUEST = 0; DEFAULT_GROUP = *,*,*,*,*; CONTROL_CODE = 00000000 00000000; /APPL AUTO_SINGULARITY_HEADER; ENABLE_SINGULARITY_AVOIDANCE : TRUE; /MN 1: --eg:Copyright (c) 2019 DIY-Robotics.com All rights reserved. ; 2: --eg: ; 3: --eg:Redistribution and use in source and binary forms, with or without ; 4: --eg:modification, are permitted provided that the following conditions : are ; 5: --eg:met: ; 6: --eg: ; 7: --eg:Redistributions of source code must retain the above copyright ; 8: --eg:notice, this list of conditions and the following disclaimer. ; 9: --eg:Redistributions in binary form must reproduce the above ; 10: --eg:copyright notice, this list of conditions and the following : disclaimer ; 11: --eg:in the documentation and/or other materials provided with the ; 12: --eg:distribution. ; 13: --eg:Neither the name of DIY-Robotics.com nor the [...]
Start/Restart Lock Cell
Start/Restart Lock Cell LANGUAGE: Karel CREATED: 2017-04-20 MODIFIED: 2019-11-21 CODE /PROG BSTARTRESETLOCK /ATTR OWNER = MNEDITOR; COMMENT = "StartResLockCell"; PROG_SIZE = 3126; CREATE = DATE 17-04-20 TIME 09:14:42; MODIFIED = DATE 19-11-21 TIME 11:34:24; FILE_NAME = BGLSTART; VERSION = 0; LINE_COUNT = 114; MEMORY_SIZE = 3458; PROTECT = READ_WRITE; TCD: STACK_SIZE = 0, TASK_PRIORITY = 50, TIME_SLICE = 0, BUSY_LAMP_OFF = 0, ABORT_REQUEST = 0, PAUSE_REQUEST = 0; DEFAULT_GROUP = *,*,*,*,*; CONTROL_CODE = 00000000 00000000; /APPL /MN 1: --eg:Copyright (c) 2019 DIY-Robotics.com All rights reserved. ; 2: --eg: ; 3: --eg:Redistribution and use in source and binary forms, with or without ; 4: --eg:modification, are permitted provided that the following conditions : are ; 5: --eg:met: ; 6: --eg: ; 7: --eg:Redistributions of source code must retain the above copyright ; 8: --eg:notice, this list of conditions and the following disclaimer. ; 9: --eg:Redistributions in binary form must reproduce the above ; 10: --eg:copyright notice, this list of conditions and the following : disclaimer ; 11: --eg:in the documentation and/or other materials provided with the ; 12: --eg:distribution. ; 13: --eg:Neither the name of DIY-Robotics.com nor the names of its [...]
Pro Home_Direct
Pro Home_Direct LANGUAGE: Karel CREATED: 2019-07-08 MODIFIED: 2019-11-22 CODE /PROG HOME_DIRECT Macro /ATTR OWNER = MNEDITOR; COMMENT = ""; PROG_SIZE = 1090; CREATE = DATE 19-07-08 TIME 21:51:32; MODIFIED = DATE 19-11-22 TIME 08:02:42; FILE_NAME = ; VERSION = 0; LINE_COUNT = 20; MEMORY_SIZE = 1390; PROTECT = READ_WRITE; TCD: STACK_SIZE = 0, TASK_PRIORITY = 50, TIME_SLICE = 0, BUSY_LAMP_OFF = 0, ABORT_REQUEST = 0, PAUSE_REQUEST = 0; DEFAULT_GROUP = 1,*,*,*,*; CONTROL_CODE = 00000000 00000000; /MN 1: --eg:Copyright (c) 2019 DIY-Robotics.com All rights reserved. ; 2: --eg: ; 3: --eg:Redistribution and use in source and binary forms, with or without ; 4: --eg:modification, are permitted provided that the following conditions : are ; 5: --eg:met: ; 6: --eg: ; 7: --eg:Redistributions of source code must retain the above copyright ; 8: --eg:notice, this list of conditions and the following disclaimer. ; 9: --eg:Redistributions in binary form must reproduce the above ; 10: --eg:copyright notice, this list of conditions and the following : disclaimer ; 11: --eg:in the documentation and/or other materials provided with the ; 12: --eg:distribution. ; 13: --eg:Neither the name of DIY-Robotics.com nor the names of its ; [...]
Mch1 Interlock Off
Mch1 Interlock Off LANGUAGE: Karel CREATED: 2019-07-08 MODIFIED: 2019-11-21 CODE /PROG INTLK_OFF_MCH1 /ATTR OWNER = MNEDITOR; COMMENT = "Mch1 Interlock"; PROG_SIZE = 1335; CREATE = DATE 19-07-08 TIME 22:13:16; MODIFIED = DATE 19-11-21 TIME 11:34:38; FILE_NAME = INTLK_OF; VERSION = 0; LINE_COUNT = 25; MEMORY_SIZE = 1607; PROTECT = READ_WRITE; TCD: STACK_SIZE = 0, TASK_PRIORITY = 50, TIME_SLICE = 0, BUSY_LAMP_OFF = 0, ABORT_REQUEST = 0, PAUSE_REQUEST = 0; DEFAULT_GROUP = *,*,*,*,*; CONTROL_CODE = 00000000 00000000; /APPL AUTO_SINGULARITY_HEADER; ENABLE_SINGULARITY_AVOIDANCE : TRUE; /MN 1: --eg:Copyright (c) 2019 DIY-Robotics.com All rights reserved. ; 2: --eg: ; 3: --eg:Redistribution and use in source and binary forms, with or without ; 4: --eg:modification, are permitted provided that the following conditions : are ; 5: --eg:met: ; 6: --eg: ; 7: --eg:Redistributions of source code must retain the above copyright ; 8: --eg:notice, this list of conditions and the following disclaimer. ; 9: --eg:Redistributions in binary form must reproduce the above ; 10: --eg:copyright notice, this list of conditions and the following : disclaimer ; 11: --eg:in the documentation and/or other materials provided with the ; 12: --eg:distribution. ; 13: --eg:Neither the name of DIY-Robotics.com [...]
MCH1 Interlock On
MCH1 Interlock On LANGUAGE: Karel CREATED: 2019-07-08 MODIFIED: 2019-11-21 CODE /PROG INTLK_ON_MCH1 /ATTR OWNER = MNEDITOR; COMMENT = "Mch1 Interlock"; PROG_SIZE = 1607; CREATE = DATE 19-07-08 TIME 22:13:50; MODIFIED = DATE 19-11-21 TIME 11:34:52; FILE_NAME = INTLK_ON; VERSION = 0; LINE_COUNT = 39; MEMORY_SIZE = 2083; PROTECT = READ_WRITE; TCD: STACK_SIZE = 0, TASK_PRIORITY = 50, TIME_SLICE = 0, BUSY_LAMP_OFF = 0, ABORT_REQUEST = 0, PAUSE_REQUEST = 0; DEFAULT_GROUP = 1,*,*,*,*; CONTROL_CODE = 00000000 00000000; /APPL AUTO_SINGULARITY_HEADER; ENABLE_SINGULARITY_AVOIDANCE : TRUE; /MN 1: --eg:Copyright (c) 2019 DIY-Robotics.com All rights reserved. ; 2: --eg: ; 3: --eg:Redistribution and use in source and binary forms, with or without ; 4: --eg:modification, are permitted provided that the following conditions : are ; 5: --eg:met: ; 6: --eg: ; 7: --eg:Redistributions of source code must retain the above copyright ; 8: --eg:notice, this list of conditions and the following disclaimer. ; 9: --eg:Redistributions in binary form must reproduce the above ; 10: --eg:copyright notice, this list of conditions and the following : disclaimer ; 11: --eg:in the documentation and/or other materials provided with the ; 12: --eg:distribution. ; 13: --eg:Neither the name of DIY-Robotics.com [...]
