MCH2 Interlock On
MCH2 Interlock On LANGUAGE: Karel CREATED: 2019-07-08 MODIFIED: 2019-11-21 CODE /PROG INTLK_ON_MCH2 /ATTR OWNER = MNEDITOR; COMMENT = "Mch2 Interlock"; PROG_SIZE = 1563; CREATE = DATE 19-07-08 TIME 22:15:32; MODIFIED = DATE 19-11-21 TIME 11:34:58; FILE_NAME = INTLK_ON; VERSION = 0; LINE_COUNT = 35; MEMORY_SIZE = 2055; PROTECT = READ_WRITE; TCD: STACK_SIZE = 0, TASK_PRIORITY = 50, TIME_SLICE = 0, BUSY_LAMP_OFF = 0, ABORT_REQUEST = 0, PAUSE_REQUEST = 0; DEFAULT_GROUP = 1,*,*,*,*; CONTROL_CODE = 00000000 00000000; /APPL AUTO_SINGULARITY_HEADER; ENABLE_SINGULARITY_AVOIDANCE : TRUE; /MN 1: --eg:Copyright (c) 2019 DIY-Robotics.com All rights reserved. ; 2: --eg: ; 3: --eg:Redistribution and use in source and binary forms, with or without ; 4: --eg:modification, are permitted provided that the following conditions : are ; 5: --eg:met: ; 6: --eg: ; 7: --eg:Redistributions of source code must retain the above copyright ; 8: --eg:notice, this list of conditions and the following disclaimer. ; 9: --eg:Redistributions in binary form must reproduce the above ; 10: --eg:copyright notice, this list of conditions and the following : disclaimer ; 11: --eg:in the documentation and/or other materials provided with the ; 12: --eg:distribution. ; 13: --eg:Neither the name of DIY-Robotics.com [...]
Prog pdemo_drop
Prog pdemo_drop LANGUAGE: Karel CREATED: 2019-07-08 MODIFIED: 2019-07-08 CODE /PROG PDEMO_DROP /ATTR OWNER = MNEDITOR; COMMENT = ""; PROG_SIZE = 1059; CREATE = DATE 19-06-08 TIME 12:46:38; MODIFIED = DATE 19-11-21 TIME 11:35:14; FILE_NAME = ; VERSION = 0; LINE_COUNT = 16; MEMORY_SIZE = 1367; PROTECT = READ_WRITE; TCD: STACK_SIZE = 0, TASK_PRIORITY = 50, TIME_SLICE = 0, BUSY_LAMP_OFF = 0, ABORT_REQUEST = 0, PAUSE_REQUEST = 0; DEFAULT_GROUP = 1,*,*,*,*; CONTROL_CODE = 00000000 00000000; /APPL AUTO_SINGULARITY_HEADER; ENABLE_SINGULARITY_AVOIDANCE : FALSE; /MN 1: --eg:Copyright (c) 2019 DIY-Robotics.com All rights reserved. ; 2: --eg: ; 3: --eg:Redistribution and use in source and binary forms, with or without ; 4: --eg:modification, are permitted provided that the following conditions : are ; 5: --eg:met: ; 6: --eg: ; 7: --eg:Redistributions of source code must retain the above copyright ; 8: --eg:notice, this list of conditions and the following disclaimer. ; 9: --eg:Redistributions in binary form must reproduce the above ; 10: --eg:copyright notice, this list of conditions and the following : disclaimer ; 11: --eg:in the documentation and/or other materials provided with the ; 12: --eg:distribution. ; 13: --eg:Neither the name of DIY-Robotics.com nor the [...]
Prog Pdemo_Homing
Prog Pdemo_Homing LANGUAGE: Karel CREATED: 2019-06-08 MODIFIED: 2019-11-21 CODE /PROG PDEMO_HOMING /ATTR OWNER = MNEDITOR; COMMENT = ""; PROG_SIZE = 1289; CREATE = DATE 19-06-08 TIME 12:50:36; MODIFIED = DATE 19-11-21 TIME 11:35:20; FILE_NAME = ; VERSION = 0; LINE_COUNT = 34; MEMORY_SIZE = 1793; PROTECT = READ_WRITE; TCD: STACK_SIZE = 0, TASK_PRIORITY = 50, TIME_SLICE = 0, BUSY_LAMP_OFF = 0, ABORT_REQUEST = 0, PAUSE_REQUEST = 0; DEFAULT_GROUP = 1,*,*,*,*; CONTROL_CODE = 00000000 00000000; /APPL AUTO_SINGULARITY_HEADER; ENABLE_SINGULARITY_AVOIDANCE : FALSE; /MN 1: --eg:Copyright (c) 2019 DIY-Robotics.com All rights reserved. ; 2: --eg: ; 3: --eg:Redistribution and use in source and binary forms, with or without ; 4: --eg:modification, are permitted provided that the following conditions : are ; 5: --eg:met: ; 6: --eg: ; 7: --eg:Redistributions of source code must retain the above copyright ; 8: --eg:notice, this list of conditions and the following disclaimer. ; 9: --eg:Redistributions in binary form must reproduce the above ; 10: --eg:copyright notice, this list of conditions and the following : disclaimer ; 11: --eg:in the documentation and/or other materials provided with the ; 12: --eg:distribution. ; 13: --eg:Neither the name of DIY-Robotics.com nor the [...]
Prog Pdemo_init
Prog Pdemo_init LANGUAGE: Karel CREATED: 2019-06-08 MODIFIED: 2019-11-21 CODE /PROG PDEMO_INIT /ATTR OWNER = MNEDITOR; COMMENT = ""; PROG_SIZE = 1059; CREATE = DATE 19-06-08 TIME 12:45:48; MODIFIED = DATE 19-11-21 TIME 11:35:26; FILE_NAME = ; VERSION = 0; LINE_COUNT = 16; MEMORY_SIZE = 1367; PROTECT = READ_WRITE; TCD: STACK_SIZE = 0, TASK_PRIORITY = 50, TIME_SLICE = 0, BUSY_LAMP_OFF = 0, ABORT_REQUEST = 0, PAUSE_REQUEST = 0; DEFAULT_GROUP = 1,*,*,*,*; CONTROL_CODE = 00000000 00000000; /APPL AUTO_SINGULARITY_HEADER; ENABLE_SINGULARITY_AVOIDANCE : FALSE; /MN 1: --eg:Copyright (c) 2019 DIY-Robotics.com All rights reserved. ; 2: --eg: ; 3: --eg:Redistribution and use in source and binary forms, with or without ; 4: --eg:modification, are permitted provided that the following conditions : are ; 5: --eg:met: ; 6: --eg: ; 7: --eg:Redistributions of source code must retain the above copyright ; 8: --eg:notice, this list of conditions and the following disclaimer. ; 9: --eg:Redistributions in binary form must reproduce the above ; 10: --eg:copyright notice, this list of conditions and the following : disclaimer ; 11: --eg:in the documentation and/or other materials provided with the ; 12: --eg:distribution. ; 13: --eg:Neither the name of DIY-Robotics.com nor the [...]
Prog Pdemo_MainSEQ
Prog Pdemo_MainSEQ LANGUAGE: Karel CREATED: 2019-06-08 MODIFIED: 2019-11-21 CODE /PROG PDEMO_MAINSEQ /ATTR OWNER = MNEDITOR; COMMENT = ""; PROG_SIZE = 1469; CREATE = DATE 19-06-08 TIME 12:44:54; MODIFIED = DATE 19-11-21 TIME 11:35:32; FILE_NAME = ; VERSION = 0; LINE_COUNT = 44; MEMORY_SIZE = 1925; PROTECT = READ_WRITE; TCD: STACK_SIZE = 0, TASK_PRIORITY = 50, TIME_SLICE = 0, BUSY_LAMP_OFF = 0, ABORT_REQUEST = 0, PAUSE_REQUEST = 0; DEFAULT_GROUP = 1,*,*,*,*; CONTROL_CODE = 00000000 00000000; /APPL AUTO_SINGULARITY_HEADER; ENABLE_SINGULARITY_AVOIDANCE : FALSE; /MN 1: --eg:Copyright (c) 2019 DIY-Robotics.com All rights reserved. ; 2: --eg: ; 3: --eg:Redistribution and use in source and binary forms, with or without ; 4: --eg:modification, are permitted provided that the following conditions : are ; 5: --eg:met: ; 6: --eg: ; 7: --eg:Redistributions of source code must retain the above copyright ; 8: --eg:notice, this list of conditions and the following disclaimer. ; 9: --eg:Redistributions in binary form must reproduce the above ; 10: --eg:copyright notice, this list of conditions and the following : disclaimer ; 11: --eg:in the documentation and/or other materials provided with the ; 12: --eg:distribution. ; 13: --eg:Neither the name of DIY-Robotics.com nor the names [...]
Prog Pdemo_Param
Prog Pdemo_Param LANGUAGE: Karel CREATED: 2019-06-08 MODIFIED: 2019-11-21 CODE /PROG PDEMO_PARAM /ATTR OWNER = MNEDITOR; COMMENT = ""; PROG_SIZE = 1059; CREATE = DATE 19-06-08 TIME 12:45:26; MODIFIED = DATE 19-11-21 TIME 11:35:38; FILE_NAME = ; VERSION = 0; LINE_COUNT = 16; MEMORY_SIZE = 1367; PROTECT = READ_WRITE; TCD: STACK_SIZE = 0, TASK_PRIORITY = 50, TIME_SLICE = 0, BUSY_LAMP_OFF = 0, ABORT_REQUEST = 0, PAUSE_REQUEST = 0; DEFAULT_GROUP = 1,*,*,*,*; CONTROL_CODE = 00000000 00000000; /APPL AUTO_SINGULARITY_HEADER; ENABLE_SINGULARITY_AVOIDANCE : FALSE; /MN 1: --eg:Copyright (c) 2019 DIY-Robotics.com All rights reserved. ; 2: --eg: ; 3: --eg:Redistribution and use in source and binary forms, with or without ; 4: --eg:modification, are permitted provided that the following conditions : are ; 5: --eg:met: ; 6: --eg: ; 7: --eg:Redistributions of source code must retain the above copyright ; 8: --eg:notice, this list of conditions and the following disclaimer. ; 9: --eg:Redistributions in binary form must reproduce the above ; 10: --eg:copyright notice, this list of conditions and the following : disclaimer ; 11: --eg:in the documentation and/or other materials provided with the ; 12: --eg:distribution. ; 13: --eg:Neither the name of DIY-Robotics.com nor the [...]
