FANUC File Management – Loading a file from a USB key
This is a tutorial to teach how to load a file from a USB key using a Teach Pendant from a FANUC robot.
+/- 5 minutes
Use a representative backup name for your folder to keep track of your modifications more easily.
- INSERT –> USB key into the Teach Pendant
- SELECT –> [ 7 ] 7 FILE
- SELECT –> [ 1 ] 1 FILE (see screenshot)
- PRESS –> [ F5 ] [UTIL]
- SELECT –> [ 1 ] 1 Set Device (see screenshot)
- SELECT –> [ 7 ] 7 USB Disk (UT1:) (see screenshot)
- PRESS –> [ F3 ] [ LOAD ]
- PRESS –> [ F5 ] [ NO ]
- PRESS –> [ F2 ] [ DIR ]
- SELECT –> [ 1 ] 1 *.* (see screenshot)
- Using arrow –> Select the program to load. (P_DEMO_DROP for example)
- PRESS –>[ F3 ] [ LOAD ]
- PRESS –>[ F4 ] [ YES ]
- PRESS –>[ F3 ] [ OVERWRITE ] (if file already exist)(see screenshot)
