Changing speed units on a point
This procedure will only change the speed unit of the selected point.
+/- 5 minutes
If the robot is giving you a max speed warning, lower the speed under this limit on the point so the robot does not fill up the log of warning.
The speed limit may vary from a robot to another.
- Using Arrow –> Scroll down and select a program. (see screenshot)
- Using Arrow –> Scroll down to the line you want to change the speed unit.
- Select the number before speed unit. (see screenshot)
- Select the desired speed unit.
