Switching User Frames without changing the physical points positions
This procedure is use to change user frame number to a section or all of a program points.
It’s important to create a backup of your settings before making any significant modifications in your program.
Make sure to switch the “Convert” to “YES” before applying the modifications.
A bad adjustment could lead to robots or tooling collisions.
- Choose the program you want to make user frame reference changes.
- SELECT –> [ 1 ] 1 UTILITIES
- SELECT –> [ 9 ] 9 Frame Offset
- PRESS –> [ F4 ] [CHOICE]
- Select the program in which the changes have to be made.
- Using Arrow –> Scroll down to the 2nd line.
- PRESS –> [ F4 ] [PART]
- Using Arrow –> Scroll down to the 3rd line.
- ENTER –> The number where the changes should start.
- Using Arrow –> Scroll down to the 5th line.
- ENTER –> A new program name (or keep the same one.)
- Using Arrow –> Scroll down to the 6th line.
- If you kept the same program name, enter a program line number where the lines with the switched frames will be copied. If you have changed the program name the step before, no “insert line” will be asked.
- PRESS –> [ ENTER ] (if you have entered an “insert line” number) (see screenshot)
- Using Arrow –> Scroll down until the next page appear.
- ENTER –> Old frame number (the frame number on which the points where reference to)
- ENTER –> New frame number (the frame number on which the points on which you want to reference them to)
- PRESS –>[ F4 ] YES (points will keep there physical position unchanged but there references will be changed with coordinate according to the new frame)
- PRESS –> [ F2 ] EXECUTE
- PRESS –> [ F4 ] YES
- DELETE –> Lines 4 to 8
- CHANGE –> UFRAME_NUM from 1 to 0.
